Cut Off Stripped Or Broken Screws - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 07:46 AM   #16
Too Short? Cut it Again!
Originally Posted by kwikfishron View Post
It’s about the only tool that will effortlessly pull about any nail, head or not if you can get a bite on it.
And the first tool I turn to when pulling nails out the back of hardwood trim or even antique flooring I remove and want to save. I never had much luck pulling things with threads out though.
The Following User Says Thank You to user1007 For This Useful Post:
kwikfishron (07-23-2011)
Old 07-23-2011, 07:51 AM   #17
Not so new
12penny's Avatar
Rewards Points: 520
Originally Posted by sixeightten View Post
A grinder is a tool that has many uses. Not like he spent $35 and destroyed it.
I understand that. And I've made some tool purchases that blurred the line between want and need. But it took longer to post the question than what it would have taken to pull, break or unscrew them.
I suspect most responses would have been different if the OP had mentioned that small fact.
12penny is offline   Reply With Quote
Old 07-23-2011, 08:43 AM   #18
Rewards Points: 558
Originally Posted by mdawson3k View Post
I did notice something though - how am I supposed to know which wheel to get? I got two 4.5" DeWALT wheels that are designed to cut metal, but the instruction specifically says "not recommended for type 1, 1a, 27a". One of the cutoff wheels I got was Type 1, so I didn't use that one. The other one is of type 27 (not in the not-recommended list), so I used it and obviously worked. Any insight into what the types are would be helpful for future knowledge.
Thanks again. I will report back again tomorrow (Sat).
Here's a little reading for you on the types of different cut off wheels: http://www.ereplacementparts.com/art...ng_Wheels.html
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
mdawson3k (07-26-2011)
Old 07-23-2011, 12:42 PM   #19
Tizzer's Avatar
Rewards Points: 460
We are thinking about using a reciprocating saw with a metal cutting blade. Does that work?
Do you already have this tool?
Tizzer is offline   Reply With Quote
Old 07-23-2011, 03:07 PM   #20
mdawson3k's Avatar
Well, I have been trying to get rid of those screws for two weeks (seriously) and have bought new driver bits again and again just to get a few more of them out (some successfully with new driver bits and some not). As soon as a new driver bit (square) is slightly rounded out (barely visible visually) after one or two screws, I can't pull any more out . I probably went through $20 worth of driver bits (Bosch and DeWALT) to pull out about 200 screws, which seems ridiculous. Those driver bits can be reused though for most work, just these screws' heads are in awful shape but holding on dearly to the support beams.
Yeah, getting a grinder (despite being cheap) seems wasteful except I have spent countless hours trying to get them out for two weeks now... My wife just read everyone's responses and is now laughing at me.
Yes, I tried very hard to break them unsuccessfully as well. Not a single one of the broke after various methods, including as suggested...
Thanks for all the input. I will report back again later today on the progress.
mdawson3k is offline   Reply With Quote
Old 07-23-2011, 05:12 PM   #21
Rewards Points: 5,336
All you needed were vise grips. Not a flashy tool by any means. No sparks to speak about, but it gets the job done.
Ron
B. Franklin 1759
Old 07-25-2011, 10:11 PM   #22
mdawson3k's Avatar
K, got all the stubborn screws out. I was able to get two more out without grinding them after switching to new driver bits (again). Thanks for all the help!
Old 07-25-2011, 11:09 PM   #23
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
When you put the new boards down use stainless Torx screws. The star head works the best. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 07-26-2011, 07:07 AM   #24
Sorry for being primative, but....
Why not just hammer them in???
I mean, your leaving screw in the joist by just cutting them off flat... Just beat them flush.
GB Greg is offline   Reply With Quote
Stripped out door hinge screws krankykitty Carpentry 23 01-16-2012 09:23 PM
How to deal with stripped out deck screws Ranger1227 Carpentry 7 06-26-2011 07:59 AM
Rusted, broken bathtub diverter screws Steve Burke Plumbing 6 02-15-2011 10:00 AM
Stripped screws in chair Paul McMullin Carpentry 4 04-06-2010 02:41 PM
stripped screws econdave General DIY Discussions 8 07-07-2009 05:23 PM
