Curved Shower Rod Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 10:27 PM   #1
Rewards Points: 160
Curved Shower rod question
I installed a new shower - the inside is about 44" by 80" high
I bought a curved shower rod - it says on the package it fits a 72" x 72" shower curtains...
What I am wondering is if I install this will it fit? Or will it bow out and water will get onto the floor?
If so I can just get a standard straight shower rod.
hellothere123 is offline   Reply With Quote
Old 10-08-2011, 10:35 PM   #2
Top bows out to give you more shoulder room, bottom of curtain lays on the tub as usual.
Hope this helps,
Joe.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 10-08-2011, 10:37 PM   #3
Rewards Points: 160
Hope this helps,
Joe.
Call me a complete idiot...do it!
It the top curves out how can the bottom be straight? I have seen splash guard that hold the curtain in...just wondering how it works?
Old 10-08-2011, 11:39 PM   #4
remodeling pro
The flexable shower curtain will conform with no problem. I suggest you get the curtain and hooks before mounting the rod, so you can verify how high to mount it. You want the bottom of the curtain to be 3 to 5 inches above the TUB bottom , so it doesn't hang in the water.
troubleseeker is offline   Reply With Quote
The Following 2 Users Say Thank You to troubleseeker For This Useful Post:
gregzoll (10-09-2011), Thurman (11-14-2011)
Old 10-09-2011, 12:41 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
If you have a tub there is no problem. There is plenty of curtain to stay inside the tub. If you are installing a curved curtain rod above a shower receptor with a low curb then you may have trouble. We have a straight curtain over a receptor and I'm always double checking to make sure the curtain stays inside where it is supposed to be. I wouldn't trust a curtain on a curved rod to not slip out.
Old 10-09-2011, 07:08 AM   #6
DIY staff
Rewards Points: 7,174
You have a 4 foot tub and a 5 foot rod----I think you will have trouble----best to get a shorter rod.
Old 10-09-2011, 12:28 PM   #7
Msradell's Avatar
Rewards Points: 132
I believe the 44" is the width of the tub not the length. I've never seen a tub that short.
Msradell is online now   Reply With Quote
Old 10-09-2011, 12:38 PM   #8
Household Handyman
Rewards Points: 1,408
Those curved shower rods are nice. Most shower curtains will "stick" to the inside of a tub when water gets on either the tub or shower curtain material. Even if you have just a short curb with a shower pan this should work if you hang the shower rod/curtain at the proper height. The curved shower rods can be shortened if necessary. It takes a bit of thought though. Measure from the middle of the rod towards each end for your new length, and place new mounting holes in the ends as they were in the original rod so they will attach to the mounting fixture(s).
Old 10-09-2011, 01:34 PM   #9
Rewards Points: 6,652
Msradell, actually in older mobile homes, they were about that small.
Old 10-09-2011, 03:46 PM   #10
I have a standard tub/shower. I love my curved curtain rod. It seems so much more spacious then a straight rod
creeper is offline   Reply With Quote
Old 10-11-2011, 10:51 AM   #11
Lloyd aka "Wood_Smith"
Wood_Smith's Avatar
I agree- once you go curved, you won't go back! ... or something like that!
Wood_Smith is offline   Reply With Quote
Old 11-14-2011, 09:19 AM   #12
kroteg's Avatar
I have a standard shower too.Look at my spam
kroteg is offline   Reply With Quote
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 06:09 AM
Custom Shower Plumbing Question PhilStubbs Plumbing 0 04-24-2011 10:39 PM
question on tile shower design racebum Tiling, ceramics, marble 19 12-19-2010 03:48 PM
Question: custom shower pan (problems) nuklep Plumbing 7 03-22-2010 07:18 AM
Question about tiny spaces in grout (shower) doogie88 Tiling, ceramics, marble 2 01-05-2009 02:51 PM
