Culture Marble Cutting - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-31-2008, 02:47 PM   #1
I have a very large corner bathroom cabinet covered with culture marble and 2 build in sinks. Over the pase 17 years, the drain on the marble has discolered and can not be taken out. I would like to cut out the 2 sinks and drop in two new sinks to correct the problem. Any suggestions as to what type of saw to use? Jig Saw with dimond blade? Router?
Thanks.
Dennis D is offline   Reply With Quote
Old 01-31-2008, 07:37 PM   #2
I say just order a new top
nacko is offline   Reply With Quote
Old 02-01-2008, 03:38 AM   #3
Rewards Points: 22
I had to fit a cultured marble top to the walls in a bathroom and used a belt sander just like a normal counter top and it worked great. I would use a jig saw and try different blades, i would make a few trial cuts in the sinks you are going to cut out before making your final cuts.
ponch37300 is offline   Reply With Quote
Old 02-01-2008, 08:05 AM   #4
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
I have cut them with a circular saw but for this I would use a 4 1/2" grinder.
Kingfisher is offline   Reply With Quote
Old 02-01-2008, 03:14 PM   #5
The sinks are oval 18" x 24" therefore, I need to make turns. Would a jig saw work with a special blade?
Old 02-01-2008, 04:26 PM   #6
Rewards Points: 5,336
Definitely a grinder. They can easily cut curves. Just have a helper with a vacuum real close.
Ron
Old 02-01-2008, 05:16 PM   #7
that's a good idea - you can get nice 4" diamond blades for grinders that will cut most anything. be warned though - you have to be very careful, its easy to cut your fingers off.
Old 02-01-2008, 05:48 PM   #8
Rewards Points: 1,232
So you are going to remove the top, flip it and cut the basins off flush with the underside of the countertop and replace with new basins? A 4" grinder is probably not going to give you enough cutting depth, and the alternative is way too dangerous for me to recommend on a DIY board. Buy new tops.
Tscarborough is offline   Reply With Quote
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
"grease pencil" on marble tiles! zel Flooring 7 04-29-2008 05:22 PM
Cutting Marble Countertop Gina Crisci General DIY Discussions 5 10-15-2007 09:57 PM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 12:27 PM
