Culligan Water Softner Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-10-2009, 07:06 PM   #1
Culligan Water softner help
Looking for some help w/ a silver series culligan water softner. The house has been vacant for 4 years. They had the valve set to soften the water but unpluged the unit. I pluged it in and hit regen and it seems to work as it was purging water for a good while from the system. I noticed a brown film in the salt tank so I guess I should clean it out good before use??
Any ideas as what to do first? Any good websites. I downloaded the manual but wanted to see what everyone thought.
Mack V is offline   Reply With Quote
Old 12-11-2009, 07:25 PM   #2
Rewards Points: 5,336
Empty the salt container completely and clean it throughly. Disconnecting it and bringing it to a lace you can lay it down facilitates the process.
Ron
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 03:32 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
