Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-02-2009, 12:26 PM   #1
Crowm Molding question. HELP!
FIrst of all I can usually figure out what to do, but I'm a little stumped on the best avenue to take with my project.
I never installed ceiling crown molding before, but decided to help some friends out. Actually it is turning out really well and they're excited.
The house is 130 yrs old, none of the walls are even, or unbowed.
Walls are curved. My first experience with the caos of the job.
My question. Need suggestion.
On the last wall 2 windows come to within 1" of the ceiling.
I was thinking of notching out the the molding at a 52" cut around the window. A real headache, but I am not sure.
Any suggestions.
Mike
MZac is offline   Reply With Quote
Old 05-02-2009, 01:31 PM   #2
LeviDIY's Avatar
A picture or two would be helpful to see...
LeviDIY is offline   Reply With Quote
Old 05-02-2009, 01:32 PM   #3
Drywall contractor
Or stop at the edge of the window on either side. Cut your piece like an outside corner and put a small return piece to the wall to dead end it....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-02-2009, 02:24 PM   #4
Old School
Willie T's Avatar
Atlanta has the right solution. If you're truly within 1 inch of the ceiling, there's not much of a way you're going to make a notch look right.
Willie T
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Exterior door molding question. amdspitfire Carpentry 3 07-12-2008 04:37 PM
Crown Molding question or trick? javan Carpentry 17 06-20-2008 06:11 PM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 02:49 PM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 02:16 PM
