Creosote Sweeping Log (CSL) - Does It Work? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 06:05 PM   #1
Rewards Points: 152
Creosote Sweeping Log (CSL) - Does it work?
So if I want to DIY cleaning my chimney I'm curious if anyone has any thoughts on whether these things actually do anything and are worth it. They can readily be found at Home Depot, Lowes, and the like for about $15 a log! Some in the industry will say they absolutely don't work...after all ....they'd be giving up business. But one more down to earth chimney service dude did recommend them. Here's a link below. I'm inclined to think they do help somewhat...but am made sceptical a bit as they come from the same source as none other than Chia Pets and The Clapper....no joke!!
http://www.jeiusa.com/index.php?opti...=82&Itemid=108
piste is offline   Reply With Quote
Old 11-08-2010, 06:54 PM   #2
the Musigician
DangerMouse's Avatar
This is what I'd recommend....and use 2 or 3 times a year on mine.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
jlhaslip (11-08-2010)
Old 11-08-2010, 08:28 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
yea but what do you clean your chimney with DM?
Tom Struble is offline   Reply With Quote
Old 11-09-2010, 06:59 AM   #4
the Musigician
The kids, what else?
DM
Old 09-10-2014, 04:19 PM   #5
The creososte Sweeping Log works !
The creosote sweeping log works !
brian223 is offline   Reply With Quote
Old 09-10-2014, 04:37 PM   #6
Rewards Points: 626
They are not a substitute for regular chimney sweeping they help keep the build up down but are in no way a replacement for giving your chimney a regular sweep a few times a year. Also only burn well seasoned wood in it.
Nailbags is offline   Reply With Quote
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 01:45 AM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 11:53 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
