I have come across access to scrap pieces of granite from a countertop installer. He said I can have all that I want because he just buries it in the ground.
I had a thread with all my plans and ideas in it, but it was too much. So I'm breaking down a couple at a time for anyone to comment on.
GRANITE:
Idea 1
I have some big pieces now that I plan to use for a bar/counter on my deck on both sides of my grill. One is 67"x18" and another is 52"x18" and a third is 36"x18". They are gorgeous. Still working out how to go about that. They have rough edges on one or two sides. I'm thinking of roughing them up all the way around and use em like that. I think its called a rock finish?
I have not decided if I wanna build it in like a cabinet for storage, or more like an overhanging bar which you could sit at and eat. Ideas? Suggestions?
Idea 2
Next idea, I wanted to use some where you step off the deck as a pad or walkway there. I've been reading about how to rough up these gorgeous stones. I'm hearing carbide sandpaper, torch and water (makes it look flamed I hear???), and using a sealer with sand mixed in.
Ideas? Suggestions? Sand between slabs? Grout between slabs? What is a "flamed" look?
I've also read the edges of the finished face are sharp and I'd need to dull those edges to keep from cutting your foot.
Idea 3
Next idea was to use all of the granite "backsplash pieces" as an edging for a flower bed which lies along the walkway to the front door. He has hundreds of "slivers" of stone that are about 4" wide, and anywhere from 6 inches, to 2 feet long, countertop thickness. Most of these are clean cut pieces. I'd use a hammer, and rough up the edges to a "rock finish" about 3 inches wide, and varying lengths, and then stagger stack them about 3 sections high as the edging to the flower bed such that from the side you have a "rock face stacked slab look and from the top you have a beaitful smooth surface finish.
Any suggestions or ideas???
Thanks for reading my post.
If I can clarify anything, please let me know.
Deck Plan. You can see to the left is where the fireplace would go. To the right is the grill with the granite chunk countertops.
