Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-13-2012, 11:52 AM   #1
Creaky/squeaky bed. Repair or replace?
Hope this is the right place to be asking. I searched the forum for similar topics but didn't come up with much. Anyway, here's my problem:
My bed is creaks. A LOT. Any time I shift position in the slightest it makes noise, let alone when I've got someone else in it. It's a cheap metal frame that I've had for years. As far as I can tell every joint in the thing makes noise. I've tightened it up to the point that if I tighten the bolts any more it causes the frame to bend inwards.
So I guess I just want to know if it's worth drenching the thing in WD-40, or trying anything else, or if I should just straight up replace it.
Cheers.
ImANoobLol is offline   Reply With Quote
Old 09-13-2012, 03:08 PM   #2
Bombastic Idiot
notmrjohn's Avatar
Originally Posted by ImANoobLol View Post
...drenching the thing in WD-40, or trying anything else
Try the wd-40 first... please. But it won't work. Try some thin rubber pads between metal parts, cut up an inner tube, poke holes for bolts. Pads under washers under bolt heads and nuts. Rubber feet on legs. Padding under box springs.
See if that quietens your bed usage.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-13-2012, 04:01 PM   #3
I say, ditch it! You deserve to be sleeping in a bed of roses.
Fishinbo is offline   Reply With Quote
Old 09-13-2012, 04:01 PM   #4
OK, sounds like a good idea. I'll give it a shot and report back. Cheers.
EDIT: The rubber, not ditching it haha hope it doesn't come to that. Roses are expensive.
Old 09-13-2012, 04:38 PM   #5
Newbie Bill
Is it the box spring squeaking or the frame?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 09-13-2012, 07:21 PM   #6
Bombastic Idiot
notmrjohn's Avatar
"Roses are expensive." And the thorns poke holes in the sheets.
biker, does anybody even have box springs any more. Seems all I see are just boxes, with fancy names, mattress support platform system, engineered mattress support system, chiroprater approv...
Old 09-13-2012, 08:55 PM   #7
JOATMON
ddawg16's Avatar
Talcum powder....or baby powder.
How is the bed made? Is it the typical headboard with side rails that clip in? Or is it a metal bed frame that bolts to the head board?
You basically need to figure out which parts are squeaking.
My wife and I used to have that problem....then we had 3 kids....bed does not squeak any more....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General Discussion 12 09-05-2011 10:46 PM
Repair / Replace Deck Railing & Balusters cs006b Carpentry 3 09-05-2010 12:07 PM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 11:00 AM
Outdoor faucet - repair or replace? ETex2 Plumbing 2 01-19-2009 03:07 PM
Repair or replace baseboard? handbanana Painting 9 04-09-2007 07:40 AM
