Crawl Space Ventilation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-15-2008, 02:19 PM   #1
crawl space ventilation
Wondering if anyone has any solutions for my crawl space air ventilation and moisture problems. I want to add vents or small windows but the foundation is completely underground. any suggestions. I have to create some air movement in the crawl space and wonder if there are any products or solutions available. Thanks.
Richmarti12 is offline   Reply With Quote
Old 03-15-2008, 06:08 PM   #2
electrical contractor
Rewards Points: 150
can you install window wells( not sure if that is the correct name, I am an electrician not a carpenter) and use an automatic foundation vent?
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 03-15-2008, 06:21 PM   #3
Do you have a 6 mil poly on the floor and up the walls? All seams overlapped by 12 inches and taped?
jaw22 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
crawl space confusion shoestring General DIY Discussions 1 07-27-2008 01:06 PM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 07:23 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 08:26 PM
