Crawl Space Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 10:35 PM   #1
Crawl space issue
My wife and I bought our first house a few months ago and I'm trying to get the crawl space in order. The crawl space has plastic laid down covered with a small amount of gravel over top of it, the perimiter is like a small ditch, wich is where water lays even thuogh i installed a sump pump. There are vents but what concerns me is this water laying in the trench.
How can I make it dry down there?
Thanks for your advice.
Horseguy is offline   Reply With Quote
Old 10-23-2007, 06:57 PM   #2
Rewards Points: 5,336
Where's the moisture coming from if the floor and walls are covered? Any moisture should be under the plastic.
Ron
Old 10-23-2007, 07:53 PM   #3
Sounds like you have a leak somewhere...If it doesnt smell like butt, then it is probably a supply line and not a drain line. Where are you located...sounds like west coast?
send_it_all is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
condensation from ac in crawl space Jack Hass HVAC 6 08-23-2007 07:01 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
Crawl Space needs "re-insulating" bigNY Building & Construction 1 10-12-2006 02:55 PM
