Crawl Space Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 08:32 AM   #1
crawl space insulation
I need to insulate a vented crawl space but I keep getting different opinions about whether to use faced or unfaced insulation between joist. I thought unfaced since it's ventilated. I'm in central NJ. Thanks
Zephyrg is offline   Reply With Quote
Old 11-07-2013, 09:04 AM   #2
Rewards Points: 13,458
I'd be using faced with the barrier toward the sub floor.
Old 11-08-2013, 09:14 PM   #3
Registered User
Rewards Points: 5,492
If in Zone 4, not required, IF solid wood subfloor and in Zone 5, use faced towards heated area. IF plywood/OSB, not required as they have they same vapor perms as faced...http://www.buildingscience.com/docum...commendations/
Gary
Crawl Space Cleanup/Insulation Outdoorbum Building & Construction 3 04-27-2013 06:27 AM
Crawl space and insulation.. valcarmo72 Building & Construction 8 02-23-2013 08:40 PM
crawl space insulation thevoz Building & Construction 6 01-09-2010 11:56 PM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 12:44 PM
Crawl space insulation howard.wheaton Building & Construction 10 10-21-2008 09:41 PM
