Craftsman Snow Blower Auger Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 05:43 PM   #1
I have a Craftsmen 24" 2-stage snow blower, model 247.886640, SN 1I083B40407, about 6 years old. It looks to be the same as an MTD blower as many of the parts cross-reference to MTD. Apparently the auger gearbox has been damaged, as I can turn the augers by hand, but the impeller shaft doesn't turn, and the shear bolts are good. Question is how do I disassemble the auger assembly to remove/replace the gearbox? Do I need to remove the roll pins connecting the impeller to the shaft? If so, do I need to remove the housing to get to them? I have the parts breakdown, but I'm stuck at getting the thing off. Any help is appreciated. Thanks.
Greybeard is offline   Reply With Quote
Old 01-30-2011, 07:40 PM   #2
A Little Of Everything
Rewards Points: 1,364
It looks to me as though you need to remove the 3 bolts holding the outside auger bearings in place. It also looks as though there are two roll-pins in the impeller. Remove those and the auger, gearbox, and impeller shaft should pull out the front.
This site might do you some good.
http://www.hammerwall.com/Manuals/Cr...al/770-10433f/
DrHicks is offline   Reply With Quote
Craftsman 536.819501 Snow Blower Pulley Spring tgice Landscaping & Lawn Care 6 12-25-2010 10:56 AM
Tempstar 80% 14yr old blower problem autocruise HVAC 11 03-01-2010 04:46 PM
snow blower drive system bsboen General DIY Discussions 0 12-25-2009 01:31 PM
How close to the ground should the blades of my snow blower be? J187 Landscaping & Lawn Care 2 01-28-2009 04:53 PM
Furnace Blower Problem SGecko HVAC 2 09-27-2006 11:16 AM
