Craftsman Garage Door Repair???? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 10:52 AM   #1
Question
Craftsman Garage door repair????
I have a craftsman garage door opener that works great except one problem when you open it it only stays up for 10 or 20 seconds then it starts to automaticly close and if you reverse that and open it it closes the same way. I've tried every thing I know how to do with it dose any one know how to make it work properly?????
swampman069 is offline   Reply With Quote
Old 07-20-2011, 11:27 AM   #2
Rewards Points: 152
First, locate your manual, or get one online, as they contain a lot of useful information, including troubleshooting, etc. Mean time, how old is it? chain drive? belt? screw? Have you been through the installation and setup procedures, and, if applicable, checked the chain or belt tension? Have you looked to see if whatever is used to switch the limit switches is actually getting to the limit switch? If a chain drive, sounds possible that you have too much slack in it. If everything else checks out, probably a board.
Old 07-23-2011, 07:24 AM   #3
Has the garage opener been working correctly and suddenly developed this fault?
You can find manuals to help you troubleshoot at the following Craftsman opener manuals
Teknuw is offline   Reply With Quote
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Craftsman Garage Door Opener Isn't Working Right? TimmyG General DIY Discussions 4 04-18-2010 02:11 PM
Craftsman garage opener freeonthree Electrical 2 11-01-2008 03:32 PM
