Craftsman Garage Door Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 10:05 PM   #1
Craftsman garage door issue
I have a craftsman garage door that will not go down. All I here is the motor whinning like its stuck. Never had a problem with it before, its about 3 years old....Any one with ideas in getting this thing fixed?
Keith vent is offline   Reply With Quote
Old 07-14-2012, 10:22 PM   #2
Rewards Points: 13,690
Open up the cover on the opener to see if the plastic gear is stripped out.
Reliece the door and see if it will open and close by hand.
Old 07-14-2012, 10:35 PM   #3
Yes I can open and close the garage door manually.
Old 07-15-2012, 06:29 AM   #4
What he said. The nylon drive gear is stripped. Kits available at Sears parts, about $30
Old 07-16-2012, 02:41 PM   #5
Unhappy
Craftsman garage door opener issue
I have a craftsman 1/2 HP garage door opener..Model No. 139.53962SRT1
in which has stopped working. I thought It may have been the nylon gear but when I took the cover off, I found the gears in perfect condition. With the cover off, I tried to close the garage door ......all i heard is clicking noises, thats it!
What could the problem be?
Old 07-16-2012, 03:04 PM   #6
Also, when the remote is pressed, I hear a clicking noise 11 times before it shuts off.
Old 07-16-2012, 03:45 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
11 times? Do you have lights hooked up? I bet not. That clinking is the light relay telling you something is blocking the safety sensor.
ddawg16 is online now   Reply With Quote
Old 07-16-2012, 11:42 PM   #8
Smile
Ddawg16,
You are smart because the problem was a sensor issue. They were not cotrectly lined up. It could've been the kids mesding around
Thanks for the help
Old 07-17-2012, 03:24 AM   #9
banhboardman is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 11:02 AM
Craftsman Garage door car remote won t work, new battery and remote. William Cook Appliances 6 01-17-2012 09:19 PM
Garage floor Tomperro Flooring 6 07-18-2011 12:30 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
