Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-23-2007, 03:09 PM   #1
Craftsman Combination Nailer/Stapler
I have a Craftsman Combination Nailer/Stapler- model# 351.184540. It fires, but the piston ram assembly gets hung up and only partially returns to it's starting position. It won't shoot staples or nails unless I manually lift the Piston Ram Assembly to the starting position, every time. Can someone tell me what is wrong and what needs to be done to fix it. I have already replaced the Nose and the Nose Plate, to no avail.
Tazmon3
tazmon3 is offline   Reply With Quote
Old 09-23-2007, 03:51 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Wrong brand of staples, needs to be oiled, moisture in the line. It could be a numer of those factors.
Old 09-23-2007, 04:34 PM   #3
Thanks gregzoll.
The Staples and nails are for that model Craftsman stapler and it is well oiled. When I had it apart, there are no visible signs of moisture. Do you know if there's anything else that could cause the problem....maybe something that would wear, that might need replacing?
Old 09-23-2007, 04:40 PM   #4
gregzoll's Avatar
Mechanical devices do wear out, and some cheaper units have been known to use plastic parts. Personally, Craftsman tools are nothing like they used to be in the past, and the quality has gone downhill.
Old 09-23-2007, 04:59 PM   #5
Thanks again. Do you happen to know of a website for do-it you-selfers that might help me further?
Craftsman miter saw woes Joebloggins` Tools 8 11-01-2011 10:13 PM
Craftsman or Troy-Bilt Chardo Landscaping & Lawn Care 11 05-07-2007 12:42 PM
Combination Kit choice PlankflooR Tools 4 12-08-2006 05:26 PM
Craftsman Table Saw Question TonyCooper Tools 2 12-01-2006 09:44 AM
Opinion on HD American Craftsman replacement windows Jims69 Remodeling 2 10-26-2006 04:02 PM
