Cracks In New Concrete - IMPORTANT - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 11:58 AM   #1
Cracks in new concrete - IMPORTANT
Hi folks....
I recently (1 month ago) had a large pad (24x26 feet) concrete pad poured for a floor of a pole building workshop. There are 2 hairline cracks developing about 10 feet apart from each other and about 6-8 feet long. They both are running the same direction laterally (24 feet across dimension). Though I was not present when they poured (contractors) wife tells me they put down rocks and rebar.
Any comments or thoughts concerning this? what can be done at this stage to minimize? what do I need to look out for?
any feedback is appreciated.
MeanGene is offline   Reply With Quote
Old 10-14-2010, 12:03 PM   #2
Got any pics?
snowcow is offline   Reply With Quote
Old 10-14-2010, 02:46 PM   #3
jlhaslip's Avatar
Rewards Points: 386
Hairline cracks aren't an issue until they begin to separate either vertically or horizontally.
What size of rebars? What spacing? How thick is the slab? Was the bar centred in the slab?
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-14-2010, 07:53 PM   #4
Registered User
Rewards Points: 4,894
These new cracks are not in the control joints already cut? http://www.nrmca.org/aboutconcrete/cips/06p.pdf
Gary
Old 10-16-2010, 08:26 AM   #5
Concrete & Masonry
Rewards Points: 470
If I had to venture a guess, I'd say the cracks developed right off of the posts, which is ironically where the control joints should have been cut.
We always isolate the posts with expansion material, to allow the slab some movement when it's shrinks, and still cut control joints.
24' x 26' is far too large for no joints, unless it's over a foot thick and had a great cure.
jomama45 is offline   Reply With Quote
Should new (one years old) concrete crack? Faulknertw Carpentry 10 05-19-2009 06:40 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
filling cracks in concrete, to prevent weed emergence? joeyboy General DIY Discussions 19 03-13-2008 10:35 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
