Cracks In My Walls - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 07:50 AM   #1
Shandre''s Avatar
Cracks in my walls
My house is apparently built on dolomite. So there is a lot of movement.
A few years ago my husband rhinolited our interior walls.
Don't think he did much in the line of expansion joints
Firstly, how do I make an expansion joint?
Secondly, how to I repair my cracks?
Shandre' is offline   Reply With Quote
Old 08-24-2013, 07:59 AM   #2
Rewards Points: 13,994
Should not need expansion joints in a wall.
Without a proper foundation any building will move.
No clue what rhinolited or dolomite even is.
What's the walls made of?
Old 08-24-2013, 08:32 AM   #3
Shandre''s Avatar
Dolomite is the type of soil my house is built on.
My walls are built with bricks and are plastered.
" Rhinolite gypsum plaster is specially manufactured as a combined basecoat and finishing plaster for internal application onto brickwork, concrete blocks, concrete and Rhinoboard, and as a finishing plaster onto sand cement basecoats."
Old 08-30-2013, 06:41 AM   #4
If all material is of good quality then there must be a problem at constructing its base or foundation.
henrylarry6 is offline   Reply With Quote
Old 08-30-2013, 09:52 AM   #5
Shandre''s Avatar
I don't have the knowledge or the finances to repair foundations. I was hoping for aesthetics advice
cracks in the but joints of the walls in the basement garoell Building & Construction 2 01-19-2012 10:37 PM
Can I run electrical wire BEHIND my basement walls? GoBengals Electrical 8 01-18-2012 08:38 PM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 02:55 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
