Cracks In Ceiling - Water Damage? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 11:47 PM   #1
Cracks in Ceiling - Water Damage?
I am a complete newbie when it comes to home repair and I will hire someone to help me out. But I was wondering if people could help diagnose my problem here.
I live on the first floor of a 3 floor building. The ceiling in my bathroom has developed small cracks. This portion of the area above the tub has also seemed to sag slightly. When I press my hand gently against the ceiling and wall in this area, it seems very soft and could break easily.
Is this due to water damage from the unit above me? I have not noticed any leaking. Or is this not even a plumbing issue? These cracks were not there before and have just developed.
Cracks in Ceiling - Water Damage?-img_1618.jpg   Cracks in Ceiling - Water Damage?-img_1619.jpg   Cracks in Ceiling - Water Damage?-img_1620.jpg   Cracks in Ceiling - Water Damage?-img_1621.jpg
kosmic is offline   Reply With Quote
Old 12-20-2012, 11:51 PM   #2
Rewards Points: 13,300
Sure looks like water damage.
Pop off some of the texture and see if it's damp or moldy.
Old 12-20-2012, 11:53 PM   #3
Ok so this is coming from above me correct? I'm hoping my HOA will cover this but they always duck out of paying for things...
Old 12-20-2012, 11:58 PM   #4
That would be my guess.
Old 12-21-2012, 08:17 AM   #5
Rewards Points: 5,974
I would get someone from the HOA to look at it before you take too much of it down. And take photos,lots of photos all through the process.
Old 12-21-2012, 08:49 AM   #6
Rewards Points: 2,238
Yeah -
It does look like water damage.
Don't tear anything out!
Have your "HOA" look at it!!
Before you do anything!
Could be a roof leak -could be a plumbing leak from, above you.
rossfingal
rossfingal is offline   Reply With Quote
Old 12-21-2012, 10:38 PM   #7
Registered User
Rewards Points: 5,266
Need a better bath fan over that shower...
Gary
Old 12-26-2012, 12:10 PM   #8
Send a message via AIM to RobertoAguiar
Had the same problem before, its moisture from the hot showers. Get a good bath fan with high CFM number so you can avoid this in the future.
RobertoAguiar is offline   Reply With Quote
Old 12-26-2012, 01:23 PM   #9
Rewards Points: 3,130
Your HOA should have absolutely nothing to do with this. If it's indeed a water leak, it would be the responsibility of whoever lives above you (or their insurance company). Or, as Roberto says, it's too much moisture from showers, the fix is on you. Get your insurance company to look at it before you tear out anything.
Old 12-26-2012, 05:47 PM   #10
Rewards Points: 1,062
Yea, humidity from a shower seems to not be enough for that extensive paint peeling. Eventually, you should also see water stains develop.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 12-26-2012, 07:18 PM   #11
Rewards Points: 744
It looks like the shower in the unit above you may have a leak. Is that a tile shower, with tile shower floor?
Seattle2k is offline   Reply With Quote
Old 12-26-2012, 11:22 PM   #12
Rewards Points: 956
thats definitely water. try to locate the source, and go from there!
federer is offline   Reply With Quote
Old 12-27-2012, 08:14 AM   #13
Time for you to have a talk with your upstairs neighbor. I'm sure they don't realize their shower is leaking.
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 09:57 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Small cracks in basement foundation letting in water! tw1208 Concrete, Stone & Masonry 10 09-29-2012 12:24 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Condensation on ceiling near water heater. EkS Plumbing 5 10-12-2010 11:48 PM
