Cracked Tile - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 09:55 AM   #1
cracked tile
we just built a home. been in for 6 months. basement has tile in bathroom and hall. tile is cracking. who is responsible? contractor, tile co. or us. still have 6 month on the one yr. thanks
nick12 is offline   Reply With Quote
Old 11-13-2011, 11:28 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
Who hired the tile installer? If the GC did, he is responsible, if you did, the installer is liable. Just curious, how soon after the concrete was poured, was the tile installed? It takes approx. 4 months for a 4" slab to dry enough for floor covering.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-13-2011, 11:32 AM   #3
cracked floor
the GC hired the flooring Co.
So there is no way he can say I have to foot the bill?
Old 11-13-2011, 11:48 AM   #4
It was laid in the early fall and the tile in early spring
Old 11-13-2011, 12:04 PM   #5
you will be responsible in a result
most likely it is a crack in foundation, and if it happed after tile was installed then who is fault is that??? -- Company which build the house? ok - inspections... no one take responsibilities court? does it worth it??
Simple solution - talk to contractor who did it - most of them will agree to come an fix a few tiles - couple hours of work. If the problem is big and there a lot of EXPENSIVE tiles needs to be replaced - talk to contractor who did it.
marins is offline   Reply With Quote
Old 11-13-2011, 12:21 PM   #6
Rewards Points: 5,336
How many tiles are cracking?
Where is the tile installed? Floor? Wall?
Was the tile put directly on the concrete floor?
Are the walls framed and covered? Concreteboard? Something else?
Ron
B. Franklin 1759
Old 11-13-2011, 01:46 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Experimenting With Chemicals 101?
Old 11-13-2011, 01:46 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
Basement? Did you see how thick they poured the slab?
Old 11-13-2011, 02:00 PM   #9
Rewards Points: 112
Either the tile moved or the concrete moved. Neither one can be your fault. Unless you dropped somethng on the tile and broke it?
Old 11-13-2011, 02:11 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Installing tile on poured concrete basement floors without using an isolation product these days is always risky business. This should have been discussed long before any tile was installed. An opportunity for the owner to upgrade to an isolation membrane should have been offered early out. If isolation membranes were offered and declined then too bad so sad for the homeowner. Sounds like a typical basement floor installation to me.
Old 11-13-2011, 02:20 PM   #11
Rewards Points: 112
The GC hired the installer. So it would have been the GC's choice on what to use. GC's problem.
The Following User Says Thank You to rusty baker For This Useful Post:
Bud Cline (11-13-2011)
Old 11-13-2011, 02:38 PM   #12
JOATMON
ddawg16's Avatar
Not wanting to hijack....but what is the 'tyical' isolation product?
I know if I'm doing it on a wood subfloor, I would be putting down cement board or hardibacker....
I have a family room (concrete slab) that I will be installing tile on in about 6 months....I would 'prefer' do it right the first time.
Old 11-13-2011, 02:50 PM   #13
Schluter's Ditra for one.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
oh'mike (11-13-2011)
Old 11-13-2011, 03:29 PM   #14
they are on the floor and are directly on the concrete. thanks for answering
Old 11-13-2011, 04:00 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ron is correct! Schluter DITRA is probably the best known with the best record of performance. There are several others. A company called Blanke has one, I think it is named Uni-mat, Problem there is they have been in several litigation's for years over their product. I have a couple of other samples around here somewhere also but the names escape me.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Carpet dug up by cat, cracked tile beycattrules Remodeling 1 04-08-2010 06:37 PM
Cracked Tile dankreboot General DIY Discussions 1 07-17-2008 01:40 AM
cracked bathroom floor tile mahjohn Flooring 1 03-05-2006 06:08 AM
