Crack In Concrete 2 Days After Pouring? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 07:56 AM   #16
Originally Posted by danreg99 View Post
I bet they will laugh if I told them to do that.
IMO I would try and see what they say when you bring it to their attention. If they refuse then go from there.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 10-14-2010, 08:03 AM   #17
Rewards Points: 484
I have attached pics. Please look at and tell me what you think? Should I bring it up to the contractor? How would they fix it? Thanks guys, you have been lifesavers in the past!
look's like boot mark's on the corner . May not had enough dirt under the corner and some one steped on it ? When taking off the form's.?? It may have been cracked and dryed more and than the crack showed up. I sure would have them come back. they will remove and their is a solution they use to bond creet togother.
del schisler is offline   Reply With Quote
Old 10-14-2010, 08:14 AM   #18
Concrete & Masonry
Rewards Points: 636
As Tscar noted, it's not a shrinkage crack, but more of an "oops" crack that was created by a human. It could be anything already listed above; got stepped on, the form was removed to roughly, the soil underneath the corner is loose and gave way when someone stepped on it, etc.........
But here's my "stab in the dark": Rain came down when the concrete was somewhat wet/green yet, and the slab got overed in plastic. Either someone accidentally stepped on the corner when covering, or set too heavy of a weight on the corner. My guess is their foot caught it as they were existing the garage door trying ot step over it.
You can have them replace the entire square up to the closest control joint, but you'll have a variation in color with the rest of the slab, at least short term.
I'd see if they were willing to just grind the joint out a little, saving some of the sawdust, adhere together with epoxy (or another appropriate product) and sweep the dust over the surface to hide the adhesive. Should be the least conspicuous approach, and easy too.
jomama45 is online now   Reply With Quote
Old 10-14-2010, 08:48 AM   #19
Custom User Title
Rewards Points: 252
Did you pay them? I'd hold onto your money until the job is done the correct way. I'm pretty sure your agreement didn't include any damaged concrete slabs.
no1hustler is offline   Reply With Quote
Old 10-14-2010, 09:00 AM   #20
No, we close on the house 11/01. I am contacting the contractor today and we will see what he says.
danreg99 is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Hairline crack on basment concrete patch job signal Flooring 6 10-05-2010 10:38 AM
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 01:59 PM
help...pouring concrete then polish bronze2273 Building & Construction 5 12-06-2009 07:09 AM
Concrete coming-cant find my crack maker justdon Building & Construction 8 09-16-2007 06:02 PM
