Crack In Concrete 2 Days After Pouring? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 09:37 AM   #1
(Pics posted) Crack in concrete 2 days after pouring?
Hi guys and gals,
I am in the process of having my house built and they poured the driveway 2 days ago. I noticed today that there is about an 8 inch crack already on 1 of the corners. Is this normal? I know concrete will crack over time... but after 2 days??? Thanks to any experts that can chime in..
danreg99 is offline   Reply With Quote
Old 10-13-2010, 09:40 AM   #2
Civil Engineer
Rewards Points: 4,954
Post a picture, that would help.
Old 10-13-2010, 10:00 AM   #3
Concrete & Masonry
Rewards Points: 650
Does it have control joints placed in it already?
Did they pull the forms off the same day?
Pics & a better explanation would help indeed.
jomama45 is offline   Reply With Quote
Old 10-13-2010, 10:05 AM   #4
I will post pics today.
Old 10-13-2010, 01:16 PM   #5
Rewards Points: 5,336
It shouldn't crack after 2 days, but how did it crack? Weight of something that didn't belong would be high on the list.
Ron
Old 10-13-2010, 01:58 PM   #6
concretemasonry's Avatar
Rewards Points: 2,654
Based on the time and location (corner), I would first look at rough stripping tactics on the forms. - Unless it started at an inside corner.
Dick
concretemasonry is offline   Reply With Quote
Old 10-13-2010, 07:53 PM   #7
I have attached pics. Please look at and tell me what you think? Should I bring it up to the contractor? How would they fix it? Thanks guys, you have been lifesavers in the past!
Crack in concrete 2 days after pouring?-img_0052.jpg   Crack in concrete 2 days after pouring?-img_0053.jpg
Old 10-13-2010, 08:10 PM   #8
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
I'm no expert, but it really looks like they did not dig deep enough at the corners. Still I can't see why it would crack right away without at least going through the winter.
Old 10-13-2010, 08:36 PM   #9
Wow that sux. Looks like something heavy got put on it. I bet they missed the rebar in that area.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 10-13-2010, 08:38 PM   #10
What do you think I should do about it?
Old 10-13-2010, 09:15 PM   #11
make the installer rip it out and repour it.
Old 10-13-2010, 09:38 PM   #12
I bet they will laugh if I told them to do that.
Old 10-13-2010, 09:55 PM   #13
Registered User
Rewards Points: 526
They did not use any isolation joint material against the old concrete filler on the brick ledge near the house: http://www.concretenetwork.com/concr...on-joints.html
Was this poured on a hot day? Those appear to be water marks.... They should have pulled those old concrete pads......
Gary
Old 10-13-2010, 10:02 PM   #14
No, the hottest that it has gotten is about 72 this week. What will happen to the rest of the slab do you think? Is there anyway they can fix this without ripping out the slab?
Old 10-14-2010, 07:10 AM   #15
Rewards Points: 1,232
That is a mechanical fracture, not a shrinkage crack.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
concretemasonry (10-14-2010)
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Hairline crack on basment concrete patch job signal Flooring 6 10-05-2010 10:38 AM
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 01:59 PM
help...pouring concrete then polish bronze2273 Building & Construction 5 12-06-2009 07:09 AM
Concrete coming-cant find my crack maker justdon Building & Construction 8 09-16-2007 06:02 PM
