Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-14-2012, 08:09 PM   #1
covert downdraft to range hood
My current downdraft top does go up and over to the side and exiting the building around 7' high on an exterior wall.
I was wondering how can I determine how the vents are routed in the wall to see how to reuse this vent. There is a flap on the outside vent and I wonder if I can see or use a tape measure to see where it turns from.
It is possible the vent goes straight up above the stove then turn.. then the conversion might go more smoothly as I tear out the cabinet above the stove only.
DIYGST is offline   Reply With Quote
Old 12-17-2012, 01:41 PM   #2
most of the downdraft vents i have seen went under the floor. pictures would help. where does the vent exit the house now? i doubt that it would be run over the stove but stranger things have happened.
Old 12-17-2012, 02:08 PM   #3
I have a soffit kind of thing with a built in fluroescent light which the cooking area is 1' lower than the rest of the house.
The ground is slab so it couldn't possibly be in there.
the exit is about 8' high and 8 feet over from the stove.
fantech outside mounted range hood fan carpdad Appliances 0 11-29-2012 01:29 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 03:43 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 11:45 PM
