Covering Window With Ply On Aluminum Siding - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 09:15 PM   #1
Covering window with ply on aluminum siding
With the storm on it's way (I may be right in the path), just wondering about the best way to attach plywood over the windows of a house that has aluminum siding and has the sides and sill wrapped with aluminum.
All but one window, which is a fairly large picture window have storm windows on the outside. Little worried about the larger window facing east.
So, just lag screws with washers and fill the holes with caulk after the ply comes down or what?
Suggestions welcome.
Thanks.
Oldhickory is offline   Reply With Quote
Old 08-25-2011, 06:08 AM   #2
Now necessarily lag screws, but at least deck size screws(#12).
Old 08-25-2011, 06:45 AM   #3
Rewards Points: 5,336
I'd avoid putting holes in the siding. Leave the windows open a bit top and bottom. Install 2x3'x on the inside accross the window frame. You don't even need to attach the 2x3's to the wall. Attach the plywood to the 2x3's with Timbertech 8" screws. Put the screws high and low enough and you can close the windows almost shut. Not that it matters with the whole window covered.
Ron
B. Franklin 1759
Old 08-25-2011, 06:47 AM   #4
biggles's Avatar
piece of PT wood 1" square the lenght of the top of the window pre drill holes in the wood 3 should do....philips head screws and cordless with screw bit..mount it on the top of the inside of the aluminum frame..so you can slide the wood panel up and into it and pin the bottom..just an idea
Patch & Paint Holes in Aluminum Siding gilbo125 Painting 20 09-21-2016 11:21 AM
where to get aluminum siding?????????? cherry_560sel General DIY Discussions 7 03-02-2011 08:46 PM
window replacement--pvc or aluminum covering the old wood?? pls help !! silvershot77 Building & Construction 6 05-27-2009 03:31 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Aluminum siding miami vice 25 Building & Construction 2 05-22-2007 03:13 PM
