Covered Porch - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 09:19 PM   #1
Rewards Points: 93
Covered Porch
Hi, I want to tear down an existing 3 season room and build a new covered porch on the back of my house. I am concerend with connecting both the deck and the roof to the existing house wall because it is half brick, and half siding. I have also heard that it is not good to tie a ledger through the brick and into the joists because the brick can be damaged by the compression.
If I build a freestanding covered deck, can I still install flashing between the new roof and the house wall? Won't it just break seal when the deck settles/wood expands and contracts each year (Pittsburgh)?
Thanks for any advise!
http://img156.imageshack.us/i/201102...odside211.jpg/
jsbeckton is offline   Reply With Quote
Old 03-04-2011, 07:16 AM   #2
Freestanding means just that, it can't connect to the house. But I am sure there are ways to connect everything to the house. The new room needs proper footings, and a plan.
I should assume you have a permit and approved plans, or at least plans that can be approved. Obviously not. Many areas of the country require permits to remove as well as build. Some even require permits to change your mind.
When I tried to open your link, my computer was attacked but blocked by Norton. Other viewers use caution.
Old 03-04-2011, 09:00 AM   #3
Rewards Points: 93
I am not looking for a structural tie to the house, I am looking for a way to keep water from running in between the house and the "freestanding" new roof, if there is such a way. If not I will look into a ledger.
Obviously I do not have approved plans or I woudln't be asking this question..... I am doing my homework.
Image shack is the most commonly used picture host site on the internet and did not "attack" your computer. You may have your Norton settings too high.
Old 03-06-2011, 08:51 AM   #4
Rewards Points: 93
If I were to make a freestanding gable roof not tied in, what supports the lateral load on the rafters? (i.e. in the direction of the ridgeboard)?
Old 03-06-2011, 11:00 AM   #5
From your photo I notice that your neighbor has a hip roof on his!
It appears that it uses a brick mounted ledger board.
A verticle load on the brick work isn't likely to be a problem. There would of course be a horizontal compression problem. of course.
However, this could easily be remedied by using sleeves for the lag bolts.
Covered Porch over Basement leaks/rotting/repair Old College Try Building & Construction 10 11-13-2013 10:37 PM
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Covered front porch deck leaking smileydave Carpentry 2 09-24-2010 06:14 AM
GFCI outdoor covered porch cept Electrical 9 08-06-2010 08:12 PM
want to build a covered porch marco fortino Building & Construction 1 07-23-2010 06:58 PM
