Couple Of Questions~Boom Lifts - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 02:18 PM   #1
Couple of Questions~Boom Lifts
We (my family and I) are considering re-painting the outside of our home. It is 2 stories high, so we will need some type of boom lift or somethin' to get the job done. I have a couple questions: 1) We have a concrete side-walk that wraps around our home and we were wondering if the concrete would be tough enough to hold the lift or if it would crack under the weight? 2) Will the boom lift do serious damage to the landscaping/grass and if so, is there something we can put down that will prevent damage (like planks of 3/4 in. plywood) ...or is it kind of inevitable?
Any advice that y'all can give me, would be much appreciated...Thanks : )
LeiselSpafford is offline   Reply With Quote
Old 11-08-2011, 04:00 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
The only person to answer the questions is the person the supplies and uses the "boom lift" the job you have in mind. - The higher the height of the work and the further the reach, the more the load on the critical wheels will be that causes damage.
A scaffolding might be an option.
Dick
concretemasonry is online now   Reply With Quote
Old 11-08-2011, 04:09 PM   #3
Rewards Points: 6,652
You have pretty much answered all of your questions. Most people use scaffolding or just ladders when painting.
Old 11-08-2011, 04:35 PM   #4
kwikfishron's Avatar
Rewards Points: 92
That’s going to depend on lots of things such as what lift you need, what obstacles are there in your yard, slope of yard, how soft the soil is and who is running the lift.
I’ve drove fairly large lifts over sidewalks without issue but might not be as lucky with “your” sidewalk. I’ve managed lifts through nicely manicured yards over doubled ¾ ply without incident but the wrong operator could easily trash a yard, plywood or not.
It’s pretty rare for a lift to be necessary to paint a house and if you needed it for 3 or more days you could easily buy a couple of nice ladders with standoffs for less than the cost of the lift.
kwikfishron is online now   Reply With Quote
Old 11-09-2011, 09:38 AM   #5
Rewards Points: 3,130
Buy or rent some ladders or scaffolding. That'll likely cost you less than just the delivery charge for a lift.
Any lift would be overkill just to paint your house. I used a 40-ft all-terrain unit when building my log house, and maneuvering it around trees was a pain. If you are spatially challenged, they are a bear to drive.
Sheetrock Ripout and Replace - Couple Questions Evil Scotsman Drywall & Plaster 5 11-08-2010 02:53 PM
couple of window installation questions wengang1 Carpentry 5 10-19-2010 08:09 AM
Basement Reno Take II...A Couple of Questions monsterbash Building & Construction 3 08-25-2010 10:16 PM
Burst of cold water while taking a shower sab Plumbing 7 07-07-2010 11:49 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
