Countertop Spacers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 09:10 AM   #1
Countertop Spacers
When installing postform laminate countertops with a front lip, is it standard (or more common) to put them on a 'spacer' between the cabinet and the area of the countertop behind the lip - so that the underside of the lip is flush with the top of the cabinet, OR put the area behind the lip directly on the counter top so that the lip hangs down infront of the cabinet ? (possibly hit drawers)
Furthermore if it is standard (or more common) to have a 'spacer' or build up, where are they placed? Along the length of the countertop ? Perpendicular to that on the joining areas of the cabinets? See picture.
I would like to know if i need to add spacer material (wood) into the budget, or if i can order countertops that have this spacer already, is it a higher price than is listed ?
Thanks in advance for any info to this 'spacer'/'build-up' topic.
Dave
drh146 is offline   Reply With Quote
Old 09-05-2011, 09:46 AM   #2
Rewards Points: 2,240
Hi!
Welcome to "DIY"!
Most of the countertops from the "Big Box" stores may not have spacers.
Tops from a shop usually do.
We usually add spacers (as you mention - clearance for the drawers).
For the spacers we would use 1 X 2's or 3/4" plywood strips.
This is a holiday weekend, so a lot of the "Pros" may not be here.
Wait and see who else has something to say.
I've done a lot of cabinets/countertops - still don't know if I consider
myself a "Pro"!
rossfingal
(I just looked and one of the "Mods" is here, he has extensive knowledge/experience with
interior work; and can give you a definitive answer)
rossfingal is offline   Reply With Quote
Old 09-05-2011, 01:45 PM   #3
Rewards Points: 5,336
I mount the spacersaround the entire perimeter of the cabinet setup as well as all the cabinet sides. You want the counter to have continuous support or it will sag in the areas without the support.
How thick the spacers are depends on how high the cabinet drawers sit. You might need thicker spacers with a frameless cabinet then a traditional face frame unit.
Before you install the cabinet, seal the bottom edge with a clear poly so water doesn't get into the substrate. Two areas particularly susceptible are by the sink and dishwasher. Apply 2-3 coats.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
rossfingal (09-06-2011)
Old 09-05-2011, 02:31 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
Since there is 5/8 inch lip just add 1/2 inch to all edges of the cabinets and you will have an 1/8 inch lip which for sure shouldn't interfere with anything, there really isn't a set rule for spacers unless it is a commercial job then it better be dead on specs. The deciding factor for me would be how much clearance will there be for the dishwasher to slide in and how much space above it even with the adjusters, also the amount of space above the drawer fronts.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
What do I do with this countertop - suggestions??? cweese Kitchen & Bath Remodeling 11 05-09-2011 06:39 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
