Countertop Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 10:05 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Countertop question
I never got around to putting the endcap on my countertop before I installed it
Now I've got the fillers glued in and the piece of formica glued on the end of it and I'm wondering if there's a tool for my dremel that will trim the excess off. I've heard that you normally would use a router, but I know the router won't go close enough to the wall.
My only other option is to pull the countertop back off, but I can't remember if it's glued or not.
Thanks in advance for any help.
Journeyman Plumber
Old 06-08-2011, 10:08 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
I just did this before work this morning. I did not have the proper router bit, and was trying to finish up the countertop (it's in a mudroom, not a kitchen). A regular file will make short work of trimming the edge down in an area where the router won't fit. A rounded file works well for inside corners as well. Just be careful to file towards the finish-face, if you go the other way you can chip off the finish. Also, don't file off the flat surface of the countertop, just the endcaps (I made a small oops with that this morning).
hyunelan2 is offline   Reply With Quote
Old 06-09-2011, 01:03 AM   #3
jschaben
Rewards Points: 502
Well, I think either a rotary file, sanding drum or carbide burr would handle the job fairly well, I think any of those are available in 1/8" shank.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
What do I do with this countertop - suggestions??? cweese Kitchen & Bath Remodeling 11 05-09-2011 07:39 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 08:05 PM
Granite tile for countertop speedster1 Remodeling 18 12-16-2009 08:16 PM
2 tier countertop dexdawg Carpentry 3 03-19-2009 03:01 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
