Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-28-2011, 11:26 AM   #1
countersink 45* angle?
I need to countersink a 1/2" lag plus washer going in at a 45* angle. With the washer on it needs to be 1-1/2 wide. I tried to use a spade bit and go in at a 45* angle and I almost had a serious injury, the bit spun right off the wood catching my shirt and winding up
Any idea how I can do this safely?
cbzdel is offline   Reply With Quote
Old 05-28-2011, 11:37 AM   #2
KemoSabe
loneframer's Avatar
drill a hole through a block of wood lengthwise with the paddle bit. Then cut the block on a 45 with a miter saw. Temporarily attach the angled block to the piece that needs the angled counter-bore and use the hole through the block as a guide.
Be very careful in clamping or screwing the guide to the workpiece to keep it stable.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
Willie T (05-28-2011)
Old 05-28-2011, 12:19 PM   #3
sdsester's Avatar
Was the bit of quality and sharp?
Usually in these situations I cut the wider recess for the countersink first and then drill whatever hole for the anchor.
You might try something other than a blade auger.
As mentioned, be careful if your bit is flying around the essence of giant pilot hole at this point.
Hole saw and chisel might help if you go slow.
sdsester is offline   Reply With Quote
Drilling angle iron to wood... atiffarooqi Building & Construction 2 06-24-2009 09:46 PM
Is It Okay To Hang A Sheet Of Drywall On An Angle? moondriver Drywall & Plaster 12 05-01-2009 04:22 PM
Tight drilling angle fw2007 Electrical 8 05-31-2008 10:33 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
