Could Loose Fill Insulation Have Asbestos? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 07:07 PM   #1
Rewards Points: 180
could loose fill insulation have asbestos?
I'm remodeling the house and have already move most of the loose fill (blown in) insulation from the rear to the front of the house. It's a 1937 house and I only know the 30 years back history of it. It looks like the $8/bag blow in stuff from HD. Someone said look at the color, if it's brown it could be asbestos (employee from Lowes), same guy didn't know what a hip roof was yet did roofing for years...
I was using a $30 mask and most of the work is done, same person suggested that I should remove all of it and get new, otherwise I could have trouble selling later. It would be pretty easy to remove now, as I have no roof on half the house.
KarlJay is offline   Reply With Quote
Old 10-08-2010, 07:41 PM   #2
honestly it could be or it may not be. Only way to tell is to have it tested.
wnabcptrNH is offline   Reply With Quote
Old 10-08-2010, 08:36 PM   #3
Civil Engineer
Rewards Points: 4,700
Vermiculite mined in Libby, Montana was used for years as loose insulation. Unfortunately, the vermiculite contained asbestos, which is therefore in hundreds of thousands of homes, possibly millions of homes, and in a lot of potted plants as well. Only way to tell if you have asbestos is to get it tested, as noted by previous poster.
Daniel Holzman is online now   Reply With Quote
Old 10-08-2010, 08:47 PM   #4
steveel's Avatar
Testing is a piece of cake. Just look up "environmental labs" in your yellowpages or internet. They'll need a small sample, in a double ziplock bag. Last one I did was $45.
However.... it sounds like you're nearly done with the job. What difference would the test make now?
If its vermiculite, then down the road your prospective buyers inspector if knowledgeable ought to raise the asbestos possibility. If it looks like the blown in cellulose, then I'd be surprised if they single that out. If it looks like cellulose only result I can see from testing (since the job is basically done) is that you might acquire actual knowledge about asbestos which you would then have to disclose when selling, instead of being able to check the "unknown" box.
I'll leave the ethics of intentionally not finding out to others.
steveel is offline   Reply With Quote
Old 10-08-2010, 11:51 PM   #5
i have to agree here. chances are, there is asbestos in your home...somewhere.
same goes for led paint. and in a few years there will be some other product that has only recently been found to cause problems. if you test it now, the only sure thing is that when you decide to sell the property, you will have actual knowledge of one or more of these concerns, and be required to disclose it.
1910NE is offline   Reply With Quote
Old 10-09-2010, 07:41 AM   #6
Vermiculite (asbestos)
Cellulose (shredded newspaper / fiber)
Cellulose has been popular for MANY years, well before the 1930's. Though fire retardant additives weren't popular until the 50's. As far as getting it tested -- it's a good idea if you're planning on doing extensive attic work. My home was built in the late 50's, as is 50% fiberglass, and 50% cellulose; next year I'll be removing both of those and replacing with new cellulose. I'm becoming weary of fiberglass these days -- I have a feeling it will be the next asbestos.
suprvee is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
2 questions about this insulation bnelson333 HVAC 3 07-15-2010 10:25 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
