Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-02-2010, 07:31 AM   #1
Cost of structural Engineer? (Just a Ballpark)
Would like to remove a wall in between kitchen and dining room. It runs perpendicular to the floor joists and sits above the garage wall. (there is a hallway in between the edge of the garage and the outer wall of the house). I would rather have a structural engineer come in and look at it and give me my options. ANY idea how much that would cost? I have been told if I open the wall up so that when he gets there all he has to do is look? I know prices will be different all over the country but just looking for what you paid, and I will have SOME KIND of idea.
THANK YOU
Evil Scotsman is offline   Reply With Quote
Old 11-02-2010, 09:14 AM   #2
Civil Engineer
If you are planning to pull a permit, and you need the structural engineer to prepare stamped plans for you that will be used to pull the permit, figure between $500 and $1000. If you do not plan to pull a permit (this is probably illegal, I am NOT SUGGESTING IT, however I suspect many people on this forum operate without a permit), and you can live with a verbal report (unstamped obviously) from the structural engineer, figure $400 or so for an opinion on what size beam you need, and a few ideas on how to connect the beam to the existing framing.
If you do hire the SE for full price, make sure the report includes a section on temporary support during installation, and includes details of the connections between the ends of the beam and the columns, as well as details of the column connections to the footers or main house beam.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Evil Scotsman (11-02-2010)
Old 11-02-2010, 09:52 AM   #3
the Musigician
DangerMouse's Avatar
There are many things the engineer/architect has to consider. Most of it involves doing the 'load-bearing" math.
He/she will likely do more than just look, like measuring. When I had the plans drawn up for my home, it was $1,600.
He's been back numerous times and has always answered questions I had on the phone.... all at no new charges, even when I offered.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 08:12 AM
Home addition cost per square foot docmattman Off Topic 5 08-16-2010 10:05 PM
cost for replacement window installation timsmeegs Off Topic 2 04-29-2010 02:14 PM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 10:24 AM
LVL Beam questions bellacosa Building & Construction 3 08-08-2006 12:14 AM
