Correct Subfloor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-13-2009, 01:16 PM   #1
Correct subfloor
Currently I have 3/4 " particle board on top of floor joists in my bathroom. I want to lay tile. I was told to lay 1/4" luan plywood ontop of particle board and then apply backerboard. Can anyone help as to if this is correct subfloor before laying tile? Do I need to fill in the gaps of the luan before applying thin set/backerboard. Help!!!
fabfive is offline   Reply With Quote
Old 03-13-2009, 03:14 PM   #2
Remodeling Contractor
not correct. For tile you need 1 1/8" of sub floor. you now have 3/4" so add exterior grade 1/2" Luan is an underlayment and has no structural strength. 1/4" CBU next with thinset and screws. The joints on the 1/2" should not be over the 3/4" ply joints. Overlap joints by 12" or so. You leave 1/8" - 1/4" gaps in the plywood and tape over them.
Old 03-13-2009, 04:04 PM   #3
Rewards Points: 5,336
Are you sure it's particle board. This has no structural use what so ever. It's used in cheap furniture. Are you sure it's not OSB?
No point in putting time and money into a project if the bones are crap.
Ron
Old 03-13-2009, 04:19 PM   #4
I assumed it was Advantec or such OSB.. Can't think of even seen only particle board used.
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Kitchen subfloor questions tishimself Tiling, ceramics, marble 7 12-09-2008 10:16 AM
Replaced section of subfloor but it's 1/16" higher. Is that a prob? Piedmont Carpentry 1 08-29-2008 11:12 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
