Which Is The Correct Adhesive To Use? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-14-2013, 08:56 AM   #1
Rav
Rewards Points: 564
Which is the correct adhesive to use?
I wasn't sure which was the best forum for this question, but I thought I'd start here. I need advise on what is the best type of adhesive/glue to use for a particular purpose. We have an old physician balance beam scale, with a platform that you stand on. There's a paper-backed covering that you stand on, and that covering is starting to peel off at the edges and corners. I think what it's glued to is made of plastic. What would be the correct adhesive to use to glue it back on? I happen to have Titebond III wood glue as well as multi-purpose Elmer's, but I'm assuming neither of those would be appropriate. I've attached two pics. Thanks.
Which is the correct adhesive to use?-cimg3308.jpg   Which is the correct adhesive to use?-cimg3307.jpg
Rav is offline   Reply With Quote
Old 10-14-2013, 10:34 AM   #2
Rewards Points: 3,718
This may help.
http://www.thistothat.com/
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Rav (10-15-2013)
Old 10-14-2013, 01:45 PM   #3
Rewards Points: 274
Wood glue wouldn’t be appropriate, try to some leather glue that would be ok with this, available in the market.
alexjoe is offline   Reply With Quote
The Following User Says Thank You to alexjoe For This Useful Post:
Rav (10-15-2013)
Old 10-14-2013, 02:38 PM   #4
custom user
Rewards Points: 150
I would use contact cement, which is probably what it was originally done with. Tape off what you don't want glue to get on, brush a coat on both surfaces and wait for it to tack up, then press it down. A roller would help.
JasperST is offline   Reply With Quote
The Following 2 Users Say Thank You to JasperST For This Useful Post:
Rav (10-15-2013), Windows on Wash (10-16-2013)
Old 10-15-2013, 01:44 PM   #5
Rav
Rewards Points: 564
I did just what you said. Taped it off, brushed it on both surfaces, removed the tape, waited 15-20 minutes, then pressed it down and rolled it tightly flat with a wallpaper roller. I was amazed at how well it seemed to bond. Right now I have it sitting under a flat metal surface with 20 pounds of weight on it to make sure it doesn't curl up until it's completely dry. Will check on it tomorrow. Thanks!
Tags
adhesive , glue , paper , plastic
Hardwood floor adhesive removal Rollotamasi Flooring 1 04-09-2013 12:20 AM
linoleum and adhesive removal, tile after dave.vp Flooring 0 11-15-2012 11:58 AM
Adhesive for R MATT foam board captainrichhill Building & Construction 2 05-24-2010 05:40 AM
Shower tile adhesive issues imcanadianeh Remodeling 2 03-26-2010 06:45 AM
Purchase Planipatch to cover the old adhesive ? jmpkiwi Flooring 1 02-11-2010 07:09 PM
