Cooktop In Island - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-24-2014, 05:05 PM   #1
Cooktop in Island
We are putting in a bigger island with a cooktop. We need to get additional power to it. Is there an easy way of doing this? Any external devices that can be mount under the cabinet? We have a large home and the electrical box is very far from the island. Seems too far to run new power through-out the whole house just to get to the island. Already considered taking an existing amp and using it but it is either not enough power for a cooktop or they are used. Need a new one altogether.
bateman2014 is offline   Reply With Quote
Old 03-24-2014, 05:14 PM   #2
Rewards Points: 12,846
A cook top needs a dedicated 220 volt line.
No clue what you mean by taking an amp.
bateman2014 (03-24-2014)
Old 03-24-2014, 05:25 PM   #3
Rewards Points: 626
Cook top gass or electric? If it is gas then 110, electric 220. Run it under the house in the crawl space and problem solved. As for amp? What the heck are you talking about?
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Old 03-24-2014, 05:28 PM   #4
Civil Engineer
Rewards Points: 4,520
Running power to an island is no different than running power anywhere else. You need the correct type and size of cable, typically home run to the panel, which is often in the basement. If you are not comfortable running a new circuit, you will need to hire an electrician for this. You also typically need to run two or more outlets on the island, which must be GFI protected. Your local building inspector will know the exact code requirements for your area.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 03-24-2014, 08:36 PM   #5
Bad use of words. Using an amp already in place is what I was referring to. I was hoping not to go thru the whole house to get it done. Looks like that is the only course of action. I understand the traditional way of getting it put in and what I need for my stove, I was just hoping for something not quite so laborious.
Old 03-24-2014, 09:53 PM   #6
Civil Engineer
By amp do you mean an outlet, a circuit, a switch, or something else? An amp is a unit of current, probably not what you are referring to.
Old 03-25-2014, 11:04 AM   #7
Referring to the fact I need an extra 20 amps in the area of the island.
Old 03-25-2014, 08:49 PM   #8
Rewards Points: 256
If you just need a 120v outlet in the island you can tap off another outlet. It is up to you to determine what your amperage needs are so you dont overload the circuit.
JustinK is offline   Reply With Quote
Old 03-26-2014, 06:01 PM   #9
Talking
Thank you!
We ended up tapping into another area to get enough amps. Thanks for all the help!
Installing Gas cooktop in island (with no gas?) claydwilli Plumbing 9 06-10-2016 06:26 PM
island cooktop - hood vent or downdraft vent maveric HVAC 9 04-25-2012 10:42 PM
Electric Cooktop too slow to heat coachgns Appliances 1 02-05-2011 04:45 PM
Moving oven and cooktop to island; need electrical advice worldtravelerall7 Electrical 3 06-17-2007 04:32 PM
Island Cooktop Lighting JBlake73 Remodeling 3 12-09-2005 05:03 PM
