Cooktop Installation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 03:36 PM   #1
cooktop installation
Instead of using silicone to seal the cooktop border to the granite, what other type of sealant i can use to seal the cooktop to the countertop???? My past experience is that silicone was really hard to take out when my cooktop broke. Someone recommended a adhesive strip that goes between the cooktop and the granite but I haven't found anything on that, and the guys at home depot and lowe's don't know a thing.... help please
el matador is offline   Reply With Quote
Old 09-08-2010, 03:46 PM   #2
Do you mean something like this?
http://www.amazon.com/Red-Devil-150-.../dp/B000NHQW3E
If that's what you had in mind Google the following terms:
"Strip Caulk"
"Caulk Strip"
bobby769 is offline   Reply With Quote
Old 09-08-2010, 03:54 PM   #3
I guess, but it says tub and wall, will that work for the cook top and look good?
Old 09-08-2010, 03:59 PM   #4
here's one that says can be used in the kitchen
http://www.tradekey.com/selloffer_view/id/3750105.htm
This stuff seems like it's meant more for the joint at a wall and counter but you may be able to use it for what you have in mind.
I myself have been thinking of what to do w/ that space between the glass cooktop and counter and might consider this one. The caulk that's there now is looking really old.
Old 09-08-2010, 04:22 PM   #5
Thank you sir, I appreciate the input!
Old 09-08-2010, 04:51 PM   #6
I don't see the need to seal the cooktop to the counter.
Ron
Old 09-08-2010, 05:04 PM   #7
In case of liquid spills.
Old 09-08-2010, 07:21 PM   #8
I've never had an issue with ,"liquid spills" is 30 years of kitchen renovations.
Ron
Old 10-04-2013, 09:28 AM   #9
The house we live in has a Jenn-Air electric cooktop that was not sealed. My husband was cooking pasta and the water boiled over and got into the electrical system and shorted it out. It now does not work...so yes it should be sealed.
Ashleybenedik is offline   Reply With Quote
Cooktop color? hgtv Interior Decorating 2 07-20-2010 11:49 PM
My first gas cooktop installation emperor_black Appliances 3 03-10-2010 03:11 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
jenn-air cooktop installation shayne Electrical 5 12-09-2008 05:23 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
