Converting Electric Heat - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-30-2013, 07:13 PM   #1
We live in a 1460 sft slip level home with no duct work. We have electric baseboard heat that is killing us because our electric bill in the winter can reach as high as $1000. We do have a basement but again no duct work. Does anyone have any suggestions for a new heating system that will drastically reduce the cost of our electric bill.
sherryewing is offline   Reply With Quote
Old 05-30-2013, 07:18 PM   #2
MarginallyQualified
Rewards Points: 2,464
The main issue is fuel source: Gas is best. Then comes oil.
A compromise is heat pump (reverse air conditioning) if it doesn't get too cold there.
To use anything other than what you have will require the installation of either duct work or pipes (plus the equipment).
Do you have a spare $10,000 or so to spend on the project?
Old 05-30-2013, 10:25 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
Wow...brutal.
Where is the home located, insulation levels, layout, etc?
Best thing to do is start by improving the home's usage of energy and then look at the retrofits.
Old 05-31-2013, 12:02 PM   #4
Special User
Rewards Points: 1,230
She would if she wasn't paying so much to heat the house!
Sherry,
Check this out:
http://www.eia.gov/neic/experts/heatcalc.xls
It lets you calculate the cost of gas, propane, oil, heat pump, etc to see which is cheaper for your locality.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-31-2013, 02:38 PM   #5
Rewards Points: 13,300
#1 Please go back and add your location to your profile, very important with questions like this.
Just go to quick links to edit.
How old is this house?
Old single paned windows?
Any insulation?
House ever been air sealed?
No matter what system you install it's going to be expencive to run without addressing the big picture.
Old 06-01-2013, 06:30 AM   #6
biggles's Avatar
hot water baseboard with propane if natural gas isn't around
Old 06-01-2013, 08:14 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
That's what I was thinking. Around here fuel oil is the the absolute worst cost wise. Propane is in much wider use where NG is unavailable. A heat pump with propane back up may be a good option if you want forced air so you can also have central AC.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Which wires do I unplug on thermostat to disable electric heat strips? mordak HVAC 5 11-03-2012 11:21 AM
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 11:05 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Cost-Benefit for electric vs heat pump, do my calculations look sound? chazman113 HVAC 13 08-13-2010 04:37 PM
