Construction Adhesives... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-29-2013, 11:07 AM   #1
Rewards Points: 117
construction adhesives...
what ones are the best/strongest for mulitpurpose uses.
echobravo is offline   Reply With Quote
Old 01-29-2013, 12:16 PM   #2
Rewards Points: 12,856
Unless you name what it is your going to do with it there's is no one size fits all on this one.
oh'mike (01-29-2013)
Old 01-29-2013, 12:28 PM   #3
DIY staff
Rewards Points: 7,174
PL premium is always in the truck--that one is good for most day to day stick-um needs---
But like Joe mentioned---different needs--different glue---
Dave Sal (01-30-2013)
Old 01-29-2013, 02:28 PM   #4
Rewards Points: 85
I like PL Premium as well. It seems to hold better and harden better than some of the other stuff.
housegsx is offline   Reply With Quote
Old 01-29-2013, 02:34 PM   #5
Rewards Points: 436
In my opinion it should be illegal to put the word adhesive on any of those tubes. Biggest waste of money there is in construction. The tube should read Mucky Puck.
Old 01-29-2013, 03:29 PM   #6
Rewards Points: 117
no real specific use, i was looking for the one size fits all..
i saw the one thread about the guy gluing moulding to the ceiling and wanted to know what would be the best "one size fits all" to have around
Old 01-29-2013, 04:33 PM   #7
loctite power grab works great depending on what you are doing with it
pl is great also. each one has their place
Old 01-29-2013, 07:16 PM   #8
Rewards Points: 2,630
ditto on the PL Premium
Excellent adhesion on wood and many other substances. Polyurethane like Gorrila glue. Stronger than the wood you are joining it to.
It expands a little as it cures. Normally I like this, because it fills the gap from less than perfect cuts. For example, if you are using it on corner miter joints on molding. But if you are using it where it will be visible, you have to remember to go back after 20 minutes and wipe off any excess that has oozed out (sometimes a little varsol helps).
Seems to work well on plastics also.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
interior construction project question kindofsudden Building & Construction 5 11-07-2012 10:51 AM
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-05-2011 12:32 AM
Can lights in insulated, existing construction? mtr_can Electrical 1 07-16-2011 09:03 PM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 07:05 PM
