Construction Adhesive - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 09:37 AM   #1
Rewards Points: 1,648
When you buy construction adhesive in a tube that you apply with a caulking gun, how do you preserve the unused portion or do you have to use it all in one shot?
They have those caps you put on top of the nozzle. I've had good luck with silicon or latex caulks, sometimes they would clog up and I just push a long nail in and that usually does the trick. However adhesives are different once they dried and cured along the shaft of the nozzle there is not much you can do. I even tried to wrap some saran wrap over the tip then push the cap down still no good.
Any tricks?
miamicuse is offline   Reply With Quote
Old 01-21-2012, 09:47 AM   #2
Rewards Points: 14,290
Gutter spike, or it's so cheap to buy just toss it.
TarheelTerp (01-21-2012)
Old 01-21-2012, 09:50 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I don't like that big of a hole in my caulk. 16d nail.
Never mind. I forgot we were talking about glue. You're right about tossing it (easy to say when you buy it by the case).
titanoman is offline   Reply With Quote
Old 01-21-2012, 01:00 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,... I do that, 'n store it in the fridge...
It'll last quite awhile...
Old 01-21-2012, 01:03 PM   #5
Rewards Points: 2,212
I put a screw or nail in it and then a strip of duct tape up one side and above it by 1-2" then back down on itself and down the other side and stick it to the tube and to itself on the sides of the tube.
mae-ling is offline   Reply With Quote
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
construction adhesive mmhendrie Building & Construction 8 03-19-2009 08:24 PM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Storing PL Premium construction adhesive Nestor_Kelebay General DIY Discussions 14 12-19-2008 07:03 AM
Use construction adhesive for box install? rgsgww Electrical 7 11-28-2008 11:02 AM
