Constant Drip On Roman Tub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 11:35 AM   #1
Constant Drip on Roman Tub
I recently tried to fix the drip on my Roman Tub. I replaced the inside of the Hot and Cold knobs with new Delta Stem Unit Assembly, Model # RP1740. After replacing the new with the old, the drip is still there. Any suggestions?
tgpitch16 is offline   Reply With Quote
Old 11-18-2011, 03:19 PM   #2
Rewards Points: 5,336
Take a look in the stem housing to see if the housing is scratched or there is some debris causing water to pass by the new stem.
Ron
B. Franklin 1759
Old 11-18-2011, 03:49 PM   #3
Thanks for the reply. Couldn't see any debris and don't see any scratches. Any other thoughts?
Old 11-18-2011, 04:09 PM   #4
Are these stems ceramic? Check for recesses in the perimeter.
The ones I buy come with protective plastic covers so the soft sealing edges don't get dinged in transit.
Ron
B. Franklin 1759
Old 11-18-2011, 04:19 PM   #5
I believe it's plastic. I've attached a link to exactly what I bought below:
http://www.amazon.com/Delta-Faucet-R.../dp/B00002N95W
Old 11-18-2011, 11:55 PM   #6
A temp. fix if the noise is an issue is to tie a string to the spout and make it long enough to go inside drain. The water will flow along the string if it is touching the water source.
MajorMedicalBoy is offline   Reply With Quote
Old 11-19-2011, 12:01 AM   #7
did you replace the seats and springs also??
Old 11-19-2011, 06:37 AM   #8
No when I took the knobs off, that was the only part to remove. Not familiar with seats or springs.
Old 11-19-2011, 02:41 PM   #9
If you look look at the link you provided, there are parts youneed to change. The black rubber gaskets and the springs. That's what stops the leak, not the stem.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
ben's plumbing (11-19-2011)
Old 11-19-2011, 06:54 PM   #10
I see the black rubber gasket but don't see any springs. Is the spring below the gasket? Also, is it as easy as just popping out the gasket and replacing it?
Old 11-19-2011, 07:12 PM   #11
Rewards Points: 582
danny hit it right on seats and springs lift out replace your good to go ...ben
Old 11-19-2011, 07:36 PM   #12
I'll give it shot tomorrow. Thank you both for all of your help.
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Constant drip from condensation pipe tootch Plumbing 2 11-15-2010 10:43 PM
Floor Drain, require constant drip? acerunner Plumbing 2 10-19-2010 04:11 PM
Constant drip in bathtub bozonoz Plumbing 1 07-16-2010 02:08 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
