Constant Drip on Roman Tub
I recently tried to fix the drip on my Roman Tub. I replaced the inside of the Hot and Cold knobs with new Delta Stem Unit Assembly, Model # RP1740. After replacing the new with the old, the drip is still there. Any suggestions?
The ones I buy come with protective plastic covers so the soft sealing edges don't get dinged in transit. |
http://www.amazon.com/Delta-Faucet-R.../dp/B00002N95W |
A temp. fix if the noise is an issue is to tie a string to the spout and make it long enough to go inside drain. The water will flow along the string if it is touching the water source.
did you replace the seats and springs also??
danny hit it right on seats and springs lift out replace your good to go ...ben
| All times are GMT -4. The time now is 08:36 AM. |
