Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-04-2009, 06:29 PM   #1
Unhappy
Connect 2" pvc drain to 2" copper pipe - no subfloor access
I am renovating my tiny bathroom and need to connect a 2" PVC shower drain to a 2" copper drain pipe. There is NO access to the subfloor unless I tear down walls AND ceilings downstairs or rip up the sub-floor - both of which are nightmare options... so I cannot do a male copper to female PVC connection or vice versa. Is there ANY WAY to join the PVC drain to the copper pipe and seal it or is there an internal seal available?
I am stuck with a tile ready shower pan with an integrated PVC drain.
missfixer is offline   Reply With Quote
Old 09-04-2009, 10:35 PM   #2
Open the ceiling under the shower and use a fernco fitting.
Patch the hole and paint the ceiling.
Ron
Old 09-04-2009, 10:37 PM   #3
Rubber sleeves and clamped with hose clamps are available! Would this resolve your problem.
Old 09-05-2009, 06:44 PM   #4
Theres more then one way.
iMisspell's Avatar
... or rip up the sub-floor - both of which are nightmare options... so I cannot do a male copper to female PVC connection or vice versa.
If you are putting a new shower pan, why don't you cut out a small section of sub-floor where the plan will be placed, do your pipe connection, then repair the floor ? Being the shower pan will be placed on top of the patch job, it will not have to be really neat.
A picture of what you have might help people give you more ideas.
A while back i used a rubber sleeve pressed into a cast-iron pipe then pounded a PVP pipe into that to extend my house clean-out an extra 6" so i could fill the cavity with conrete, but that was a cast-iron pipe, not shure i would try that with copper, it might tear.
The thing i used (sorry i forget the name), kind of looks like this picture, except that the smaller end would not have a hose clamp and that smaller end would slide the copper pipe then the pvc would slide into that.
Kind of like an ID (Inside Diametor) rubber sleeve. Where the PVC would slide in was ribbed.
Again, i dont think something like this would work with copper, but not being a plumer, maybe im wrong.
What ever you do, when your dealing with water, taking the easy short-cut will more then likley come back and bit you.
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience -
- Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Tags
copper, drain, join, pvc
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 04:33 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 11:47 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
