Condensation Won't Drain In A/C Pan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-01-2014, 11:40 AM   #1
Condensation won't drain in A/C pan
I have a Nordyne Vexar Model 1836QA. This is in a manufactured home. I found that the condensation was up to the top of the drain pan - not draining. I have no idea where to begin to trouble shoot this issue. Any help would be appreciated.
Thank you!!!
dnewman07 is offline   Reply With Quote
Old 04-01-2014, 03:08 PM   #2
Rewards Points: 14,312
Run a snake down the drain line.
dnewman07 (04-01-2014)
Old 04-01-2014, 04:17 PM   #3
Rewards Points: 6,034
Find the corner that has the drain and run a snake or stiff wire down it.
Old 04-04-2014, 03:29 PM   #4
Rewards Points: 121
Don't know the area you are from. But it is very common here in the deep south for our A/C drains to clog up with mold, mildew and other crud quite often during the summer months. About once a month mix up a mixture of hot water and bleach an flush out the drain lines. There are commercial cleaners available that may be more environmentally friendly.
jrepp44 is offline   Reply With Quote
Very old scupper drain system presents unique replacment challenge-PICS mysterylectric Roofing/Siding 0 10-26-2012 08:05 PM
Furnace Condensation Drain sbkim HVAC 10 10-22-2012 07:01 AM
A/C condensation drain slime tndiyguy HVAC 2 08-28-2011 01:25 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
