Condensation On Metal Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 10:59 AM   #1
Condensation on metal door
Hi, i'm really hoping somebody on this forum can help me!
I moved into a rented flat in September - but since the weather has got colder I have had some really bad problems with condensation and resulting mold.
Turning the thermostat up has fixed most of the condensation - apart from the metal door in the bedroom leading to the outside. The frame is very cold and gets damp extremely quickly, I dry it out and it's wet almost straight away.
Is there anything I can do to the door frame to stop it from getting so cold?
Thanks a lot,
Jon
Yonna is offline   Reply With Quote
Old 11-13-2010, 11:27 AM   #2
Rewards Points: 1,092
Condensation happens when warm, moist air hits something cold. If you have high humidity, do whatever you can to lower it, ie, run an exhaust fan (esp when making excess water), and/or run a dehumidifier. Approx 40% relative humidity is about right for health. If possible, insulating the door w/ foam on the outside may help; if the inside is warmer, it won't condense as much.
Old 11-13-2010, 02:59 PM   #3
Rewards Points: 5,336
Is there a pattern to the condensation? Around the perimeter? Middle of the door?
If around the edges, install weatherstripping around all 4 sides. If in the middle, as previously ststed, the humidity is too high in the house.
What sort of heat do you have?
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Yonna (11-14-2010)
Old 11-13-2010, 03:19 PM   #4
Ron: good points. I should have asked "where is it". j
Old 11-13-2010, 04:56 PM   #5
Thanks for the replies.
When I check back after drying it the condensation seems to form from the bottom up. The sides are damp too aswell as the centre between the two panes of glass - but the top seems unaffected and the glass is fine.
Old 11-13-2010, 07:19 PM   #6
check your weather stripping, as suggested. i suspect the top seems fine because air is going out there. either way, seal. good luck. j
The Following User Says Thank You to jklingel For This Useful Post:
Yonna (11-14-2010)
Tags
condensation , moisture , mold
Repair of Door with Metal Interference Weatherstrip KAdams4458 Carpentry 4 09-18-2009 08:38 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 05:55 PM
Condensation on Metal Window Frames: Should I Caulk? xquercus General DIY Discussions 6 06-29-2007 09:24 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
