Condensation -Ceilings - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 04:19 PM   #1
Plaster Ceilings are showing new discoloration or possible water stain. I am not ruling out a leaky pipe, but, recently we found and repair/clean mold in our attic. Inspecting our ceilings below the attic and on our first floor, we are seeing slight darkening, the width of joists on plaster/lathe ceilings.
Is it possible, the cause of the mold in attic (poor ventilation-broken fan) is the cause of this and if so, how do we make sure this is the issue, not a broken pipe some where. ?
Should I open up a ceiling to look for moisture between flooring, condensation between the floors ?
Also, we added new more efficient windows in our home and insulation in our attic. Could we over-sealed our home ?
thank you
cblinc is offline   Reply With Quote
Old 07-26-2011, 06:15 PM   #2
Rewards Points: 2,634
Where are you located? Is it very humid ?
Did you only start seeing the dark areas on your ceiling in the summer? Do you have pipes in your attic ? Cold water running through a bare copper pipe can definately sweat in moist summer air. But I would only expect to see stains directly below the pipe.
What temperature do you have your air conditioner set at ?
I can not see how better insulating your home can cause these problems, but maybe somebodey else can see a possible link. You say you had mold in the attic before. Please give more details. Normally I expect to see a vapor barrier on top of the ceiling, and then insulation on top of that.
You found darking on the first floor ceiling. How many stories is your house ?
SPS-1 is online now   Reply With Quote
Old 07-26-2011, 10:10 PM   #3
Rewards Points: 5,336
Mold in the attic is likely from a roof leak unless you have an A/C air handler up there with a leaking tray or clogged condensate pipe.
If you think there are leaking pipes in the attic, go up there and investigate. Pipes are not run in the attic in cold climates as a rule.
Ron
B. Franklin 1759
Old 07-27-2011, 07:35 AM   #4
to add to my inquiry, 2 story home, very faint "ghosting" on newly painted (2 years ago) ceilings on first floor, humid climate (New jersey) with little or no ventilation in attic for 6 months, mold as remeadiated, cause was vapor barrier on inside roof - but my issue is now cracks and water ghosting on ceilings...could this be caused by humidity in between walls/ceilings-floors ?
Old 07-27-2011, 10:36 AM   #5
Have you correctly vented the attic? If not, start there.
What is, "water ghosting"?
Ron
B. Franklin 1759
Old 07-27-2011, 06:36 PM   #6
Yes, we replaced attic fan and thermostat and added a humisistat. My thinking is, the trapped air in attic, humid/hot, creeped down into walls and ceiling joist areas, only to then cause condensation from pipes between floors. No visible moisture, just a slight dis-coloration or "ghosting".
Old 07-27-2011, 09:58 PM   #7
An unlikely scenario. The water would need to condense onto cool surfaces, like a cold water pipe running through the attic.
Do you have cold water pipes up there? The pipes generally run in walls and in floors under the bath and are kept away from areas that could cause them damage.
Why would you add a humidistat? The humidity in the attic would not be any greater then the outside air that it was being replaced by, unless you were venting the bath air into the attic and not to the exterior. Air conditioning in the house would reduce the humidity substantially, so it would be less humid below the attic.
The discoloration is probably dirt.
There's something else going on there.
Ron
B. Franklin 1759
Tags
ceiling insulatio , ceiling joists , plaster walls , water damage
insulation in slanted ceilings dhonn Insulation 10 05-05-2011 12:38 AM
Really Condensation? Or is it a Leak? DTproject Plumbing 6 02-21-2011 07:01 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
aluminum windows condensation smalan Building & Construction 2 01-02-2009 07:51 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
