Condensation In Cathedral Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-07-2008, 02:16 PM   #1
condensation in cathedral ceiling
I am trying to solve and correct a problem in an unfinished attic space where we are working to create a bedroom in an old attic space , we have just put on a new roof and i installed soffit vent ,ridge vent and baffles to create air flow and then i added cathedral ceiling insulation in rafters but have not gotten the drywall up yet , We have now found that the underside of new roof under baffles is condensing bad need the best fix to correct this
ecoyogurt is offline   Reply With Quote
Old 12-07-2008, 03:32 PM   #2
Rewards Points: 5,336
The warmer air of the room is coming into contact with the cooler exterior air. There are gaps in the insulation or the vapor barrier. A continuous 6 mil plastic vapor barrier is much better at sealing the space then foil or kraft paper insulation.
Ron
Old 12-08-2008, 05:56 AM   #3
Unico & Buderus
Cathedral ceilings are a real challenge. As an alternative to batts and poly, you can also use spray foam insulation. A closed cell foam not only insulates better than batts (higher R value per inch) but it also acts as an excellent vapor barrier between the living space and the underside of the roof or baffles. You will have to do some searching to find a contractor in your area.
donimbimbo is offline   Reply With Quote
Old 12-08-2008, 08:06 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Did you install faced, or unfaced insulation?
If it is unfaced insulation, do you have a vapot barrier installed over it, facing the warm space of the room?
- Build Well -
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
inulation above cathedral ceiling LanterDan Building & Construction 14 06-11-2008 02:57 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 10:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
