Condensation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-06-2008, 03:32 PM   #1
Unhappy
Condensation
I have a screened in deck ( 12ft. x 20ft.) which is covered in plastic for the winter. The fiberglass roof, to let in some light, drips constantly. Does anyone know if a humidstat will work in below zero temperatures.
rmoore is offline   Reply With Quote
Old 12-06-2008, 04:35 PM   #2
It would be like trying to bail out the Titanic with a tea cup. Every time someone opens a door it will just add more moisture to the air.
You have a warm air mass hitting a cold surface. The only thing you can do is to increase the distance between the moist warm air and the cold surface by putting in insulation.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-07-2008, 09:51 AM   #3
Rewards Points: 5,336
How does a screened porch in below freezing temperatures get warm enough to drip ? Is there a source of warm moist air escaping from the house? Kitchen or bath exhaust fan? Windows open slightly?
How often do you go out the door to the porch? Is there snow on the roof?
Ron
Old 12-07-2008, 10:51 AM   #4
Ron
He has the screens covered in plastic and the porch is attached to the house. This will keep in enough heat to cause these kind of problems. Even the slab it is probably on will keep enough heat in there to keep the place above freezing.
If he were to remove the plastic the problem would go away.
Snow on the roof would actually improve the situation. Snow is a great insulator. My life and the lives of others have been saved because of snow caves.
As the temperature rises so does the ability to hold moisture.
Condensation from Ceiling AC Vent meth HVAC 29 12-15-2013 12:02 PM
A Leak and Why No Condensation from AC? sneaky_pete HVAC 3 08-19-2008 06:55 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
Condensation blowing off A coil into plenum kona1406 HVAC 6 05-26-2007 08:50 PM
Air Conditioner Condensation Issue Unregistered HVAC 1 07-23-2004 03:10 PM
