Concrete Slab Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-10-2007, 01:50 PM   #1
I have made a hole about 1' x 3' in the slab in a bathroom in order to move the toliet to another wall. My question is can i just replace the gravel and what is left of the wire rebar and fill, or do I need to replace the plastic vapor barrier and put in new wire rebar? If i need to put new vapor barrier in, how do i do that effectively as some of it has ripped out from under the remaining parts of the slab... is there anything else i should do in order to seal this part of the floor, i will be putting ceramic tile over it afterwards.
sportnmud is offline   Reply With Quote
Old 10-10-2007, 09:29 PM   #2
Custom Cabinet Maker
undercut ( dig under ) the old slab a bit slide new vapor barrier under it, replace gravel, wire, pour, float off done
skymaster is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
