-   -   Concrete Slab Repair (http://www.diychatroom.com/f2/concrete-slab-repair-12280/)
sportnmud 10-10-2007 01:50 PM
I have made a hole about 1' x 3' in the slab in a bathroom in order to move the toliet to another wall. My question is can i just replace the gravel and what is left of the wire rebar and fill, or do I need to replace the plastic vapor barrier and put in new wire rebar? If i need to put new vapor barrier in, how do i do that effectively as some of it has ripped out from under the remaining parts of the slab... is there anything else i should do in order to seal this part of the floor, i will be putting ceramic tile over it afterwards.
skymaster 10-10-2007 09:29 PM
undercut ( dig under ) the old slab a bit slide new vapor barrier under it, replace gravel, wire, pour, float off done
