Concrete Shower Pan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 02:47 PM   #1
concrete shower pan
I am remodeling our bathroom and I want to remove our shower pan that seems to be filled with concrete. What is the easiest way to do that?
rrickeard is offline   Reply With Quote
Old 09-17-2011, 03:33 PM   #2
concrete shower pan
If the shower is on a wood sub floor i wood use a saw with a concrete blade,you can use the 5.00 blades at home stores have.just score the top of the pan in strips,then use a hammer to break it up in one area so you can see how thick it is.it should come up easy.you may not even have to saw it.try hammering on it first easy.the viberation with the hammer might be enought to break it up.be VERY easy around drain.that concrete cant be over 2" thick.GFI if saw is used.good luck,ken
We all no alot but can only do a little-----an
kchunt is offline   Reply With Quote
Old 09-17-2011, 04:02 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is the subfloor wood or concrete?
If you can't get the base to readily break apart with a three-pound sledge hammer in just a few minutes of trying, then go rent a small "chipping hammer" and break it apart.
Old 09-17-2011, 04:56 PM   #4
It's concrete.
I went and bought a mason chisel and a 3lb hammer. Hopefully I can break it up with that.
Thanks for all the ideas
Old 09-17-2011, 05:19 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If it is concrete (subfloor) then there could be three ways it was installed. One would be over a layer of roofing felt. If that's the case it should break out without any issues.
Another way would be to bond the cast to the subfloor. If that's the case you have your work cut out for you.
Yet another and most likely, would be to cast the base on top of the subfloor without anything between the two. That also shouldn't be too difficult.
If it was me (and it isn't) I wouldn't screw around with it. I'd use an electric chipping hammer and get it done. Would take about fifteen minutes usually.
Old 09-17-2011, 05:49 PM   #6
It looks like it's in a metal tray if sorts. I can wiggle a crow bar under it and it lifts up, its just way too heavy to move so I need to break it up some.
Old 09-17-2011, 05:51 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Probably in a lead tray. Force your bar under the slab as much as you can then hit it. Any voids under the slab will make the concrete break easier.
Old 09-17-2011, 06:48 PM   #8
Worked like a charm! Thanks! A lit easier than I thought it would be!
Old 09-17-2011, 07:05 PM   #9
Military Mom of 4
Snav's Avatar
Hooah
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 09-17-2011, 07:34 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now, when it goes back in (assuming you are rebuilding the shower) there are improved methods to use. You are aware of that are you not?
Old 09-17-2011, 07:49 PM   #11
Actually we aren't. This is an extra bathroom for the basement. The area was so cramped with the shower in it, we decided we really didn't need the extra shower... For now, at least. :0)
Thanks for all your help!
Old 09-17-2011, 08:23 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay then...a real headache has been diverted.
Good Luck.
How to install a concrete shower pan over dirt run2smiles Flooring 10 01-03-2013 04:49 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
Do we have to break the concrete floor for a shower drain? Mechelle Plumbing 41 07-30-2008 08:59 AM
