Concrete Settling Away From House ???? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 09:20 PM   #1
Concrete settling away from house ????
Hello: I found this site while searching for an answer and then searched here before posting.
I have a poured concrete driveway that touches and runs the down the side of my all brick home. The joint between house and driveway appears to have been sealed at one point but has settled about 1" or so judging by the line of of Grey Rubber-like Caulk still attached to the house.
Any tips on re-sealing this joint?
ELECTRIC07 is offline   Reply With Quote
Old 03-12-2009, 07:13 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
It depends on how wide the joint is. If it's a half inch or less, clean it out well. Remove all of the old caulk. Install a non-absorbant backer rod and fill it with a gun grade urethane caulk. Keep the caulk bead within the dimensions recommended by the manufacturer for depth and width. If it's wider, clean and remove all of the old caulk. Install the backer rod and fill it with a pourable urethane sealant.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 06:28 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
