Concrete Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-22-2004, 11:21 AM   #1
Exclamation
Concrete question
Is there a special mix of concrete that I have to use and is there an additive that I must add to prevent the concrete from freezing?
Daniel O'Connor is offline   Reply With Quote
Old 11-22-2004, 02:54 PM   #2
Guest
Guest
Posts: n/a
No mix is freeze-proof - and concrete has to be protected from cold weather (not just freezing temperatures) during the curing process,regardless of the mix, in order for it to obtain the ultimate "design" strengths.
Various admixtures may be used to improve "workability" or accelerate curing during a cold weather placement / finishing process. Talk to your local ready-mix supplier about what you're trying to accopmplish and they can make appropriate reccomendations. Also see http://www.askthebuilder.com/printer...eather.shtmlIf and http://www.gogenchem.com/calcium/Ind05.pdf
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Concrete slab question houdinihar Building & Construction 2 06-07-2006 08:04 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
